Tire Size Question
Veloci_G
LAT 29 76 63.01N LON 95 36 45.10W
After noticing that the fronts are 225/45/18 and the rears are 245/45/18, questions questions questions. Not rotating tires due to different sizes = caca. So......what size would be suggested on next set to have all 4 same size? Should I split difference & go with 235/45/18 all 4 corners? Go with the smaller 225s like up front and have wheel gap in back? Go with 245s like in back and have possible rubbing issue up front with steering? Is this the way tire sizes are on track models or do they have all 4 same size?
Looks like you never got an answer. If your car is an Rspec or Track, the wheels are different sizes, that's why the tires are; they are staggered on purpose for performance. If you want to go the same size all the way around, you will have to go with the base model 18" wheels and then you can get the same size tires. Also you can still "rotate" the tires, you just don't rotate like regular tires. When rotating, you actually switch the tires back and forth, i.e. front left goes to front right and vice versa, and rear left goes to rear right and vice versa. This should be done by an experienced tire shop especially if your have "directional" tires, meaning they are supposed to turn in one direction.
