Transmission shifting problems between 2 - 3 and 4 - 5th gear.
I'm trying to find out the same.... TSB ....2 solenoids or all of them...and or valve body. We all need Gettosleds help !!!
My apologies for the delay. The entire valve assembly was replaced including all solenoids from a (tested) donor transmission.
Figured that is what you did, it's too much of a gamble to just replace some parts on the valve body, which is why my rebuild had the same issues before and after
Where did you buy the valve assembly? I have a 12 R Spec with the same issue
The shop that did the repair salvaged it from a wrecked Genesis.
