Trunk Release - Rubber torn
Scooby
Wake Forest NC
Does anyone know if the rubber grommet that you touch to open the trunk lid is covered under warranty or a 'wear and tear' item? Mine is torn and the car has 22K miles on it. Thanks!!
My opinion would be yes, but my opinion does not count. I'd call the dealer or ask when I was going in for next service.
I would most certainly think that would be a warranty item.
$30 - $50 and takes like 10 minutes to swap out.
Just found I have same issue at 27k miles on 2016.
Any updates out there?
Is not the bumper to bumper warranty 3 years 36000 mi.?
Local Dealer capital Hyundai here took a look at my deteriorated switch cover and ordered a new one under warranty without hesitation;
Tech said "it's a common problem"
I'm 2nd owner of my '16 3.8, so I know I have less warranty than some of you, but kudos to Capital Hyundai.
pretty common from all brands, I replaced the one on my wife's 2007 Camry 3 times in 10 years, Finally taught her to use her fob and not the switch on her 2017..
Did you buy your car there?
"Did you buy your car there? "
No, they don't know me at all until now. Car was delivered to Deland FL and I bought it used near Orlando in May.
Same thing happened to mine. Took the car to the dealer and they replaced it for free. The dealer told me it was an OEM part that should not be going bad so quickly. My car had around 54,000 miles at the time of replacement.IMG_20180730_151710419_HDR.webp
I just bought a used 15 Genesis 5.0. Did not notice this issue until a few days after purchase. Dealer is quoting $800 for parts plus labor to repair, and says not a warranty item (is this not between the bumpers as in "bumper to bumper" warranty???) . After some pushback, dealer is contacting Hyundai to see it they will cover it as a goodwill gesture. FYI - apparently the central locking system is also not covered.
I just bought a used 15 Genesis 5.0. Did not notice this issue until a few days after purchase. Dealer is quoting $800 for parts plus labor to repair, and says not a warranty item (ist his not between the bumpers as in "bumper to bumper" warranty???) . After some pushback, dealer is contacting Hyundai to see it they will cover it as a goodwill gesture. FYI - apparently the central locking system is also not covered.
typical dealer idiocy. .
that is a $40 part and takes 10 minutes to swap.
Just did the wing badge swap today and discovered the rotted out switch cover on my CPO 2016 that I bought earlier in the month with 12k miles. Looks to be a poor quality part given this early and seemingly common parts failure.
This will be my first repair for the car and having bought the car out of state will have to decide on a local dealer to do the work now. Thinking this should have been caught in the CPO inspection process but was never given any inspection paperwork when I purchased so am guessing here. Hope this first experience goes well.
What part number is the rubber cover? The only thing I can find, and what Hyundai Corporate has told me, is that the rubber on the latch is tied to the switch assembly AND backup camera.
If the rubber cover can be ordered separately, please let me know as I'd rather spend $40 than $200.
Part No.: 95760
Part No.: 95760
Replying to myself, but I believe I have found that part, it should be 81260. It's just the rubber housing, sans the camera bracket, the camera, and the o-ring around the camera.
I'll update later to see if this is indeed the correct part. If anyone knows for certain and can confirm, that'd be sweet.
17897
Just wanted to do my due diligence and confirm that 81260B is the correct part number for this piece. It's list price is $56, give or take.
Only bumping because too many threads have this happen where a conclusion is reached for a niche issue, but left ambiguous in the post. Hopefully should anyone else run into this issue they'll be able to get the correct repairs done.
Hello all
I have the same issue. I bought the part and want to replace it. Can anyone help me with the instructions on how to do it?
