Uneven Shifting, Lag and Throttle Sensitivity
JCook63
Have 2015 50
purchased at 45K miles, soon after transmission was slamming into gear when accelerating. After raising ___ factory replaced tranny. Still noticing uneven shifting when cold, very serious lag from slow rolling start or standing start when pulling out in traffic with pedal down and turning- dangerous actually. In regular drive the throttle is feather sensitive to light deceleration or acceleration if my foot isn't perfectly still- not as bad in economy . I'm wondering if this is a throttle sensor problem or similar something rather than the tranny. Any feedback is appreciated.
My 2015 AWD 3.8 has that lag when heavy on the pedal from a stop and turning. It's the traction control cutting the throttle because the front inside tire starts to break loose. I don't think it's quite as dangerous as it is surprising. Usually only takes a second to recover.
Does the engine rev smoothly in neutral? Most quality scan tools would show pedal and throttle body positions. My cheap GDS/VCI knockoff will read those.
Do you use the paddles? I find it messes with shift points after using them, coming to a stop and driving away. Long lags before up-shifting.
Have 2015 50
If tranny was fully replaced, then check the throttle body and its position sensors.
Also, was the torque convertor changed as part of the new tranny?
