USB problems
shutterpro
South Texas
I am trying to hook up my tmobile mytouch 4g using USB and it keeps giving me connection failed......not recognized. I know it's working because it will charge phone but that's it. What am I missing?
Does the cable do USB Storage with your PC? It might just be something as simple as a cable that doesn't have data lines, just power. Some MFRs are shipping phones with power-only cables. It's pretty slimy, if you ask me, but shrug.
Works fine with PC. Daughter has same phone and hers actually worked in car at one point but then stopped. It seems like it has something to do with the phone settings, but I have tried everything I can think of and even called phone carrier.
If you haven't fixed it yet, make sure you have mass storage enabled immediately after you plug in the USB cable(on myt4g i think you pull down the message notification bar and click it). Also, make sure debugging mode is not on, usually under menu>settings>applications>development>debug mode
Check to see if the USB in the Genesis will play music from a USB jump drive like a cruzer.
