What type of AWD system does the G70 use?
A lot of that is just advertising, unfortunately. Not all of those systems are created equal. Some brake-based torque vectoring systems have the words "active" in it, despite being inferior to a clutch type system.
The WRX STi's center diff is essentially an electronically controlled clutch type coupling mated to a mechanical LSD. This allows their software to control some of the power transfer between front and rear, but it is unable to send all the power in either direction, as even if the clutch is fully locked the mechanical differential will still allow for some slip (ie front or rear wheels to spin at slightly different speeds, relative to each other).
Hyundai's HTRAC is different. The power is sent through a transfer case, which acts more like a welded differential (ie running fully locked), but it has an elaborate electronically controlled clutch system that allows all power to be sent it either direction, or even a perfect 50/50 distribution. The difference here is that it is ALL electronically controlled, there is NO mechanical differential or passive power transfer dictated by a differential - every bit of power transfer is controlled by the computer. Nothing analog about it.
The examples I have are actual active differentials. I hate the brake based ones and how in the past few years they are calling it active and giving it fancy names.
I know the G70 uses brake based torque vectoring but since it is RWD based, it at least pushes you through the corner with the rear bias. The FWD based brake torque vectoring just cuts the power and you can notice that the vehicle is slowing down through the corner.
Of course nothing beats an Active Rear Differential which makes taking corners feel like you're on rails!
I'm right there with you, but just trying to make sense of the slide that @Slip_Angle posted.. The pics you posted, as far as I understand, are for HTRAC in general. There is a possibility that the G70 has a revised version of it, allowing said configurations to take place? Maybe? To me, it seems like the Magna supplied transfer case should be able to do it. In fact, Magna themselves state that the ActiMax transfer case can apply 100% of torque to either the front or rear end of the drivetrain. It uses an electronically controlled wet clutch to do this.
I'm no expert either, but I have done a lot of work on cars, including AWD cars - but still, not an expert. According to the articles I found in my first post of this thread there are some Audi and BMW models that use a system (be it transfer case or coupling) that can completely disconnect the front and/or rear wheels for fuel economy. I'm not exactly sure which models have said systems, though.
Those images are from the G70 AR brochure. G70 specific. Not HTRAC general.
The 3.3 trims in the US have a clutch-type LSD in the rear, even on AWD models. No brake based torque vectoring, at least in the rear end! But still, you're right, it wouldn't be considered an active diff, as it's still all mechanical. Even so, I still consider this a plus, as it's much much better than that silly brake based stuff, but not quite on par with something like BMW's E-Diff found on the latest M2/M3/M4.
Ah, I gotcha. Didn't realize that! Now we gotta figure out how that slide that slip angle posted fits in with everything... We must find the truth!!
The 3.3 trims in the US have a clutch-type LSD in the rear. No brake based torque vectoring on those models, as least in the rear end! But still, you're right, it wouldn't be considered an active diff, as it's still all mechanical. Even so, I still consider this a plus, as it's much much better than that silly brake based stuff, but not quite on par with something like BMW's E-Diff found on the latest M2/M3/M4.
Even with the LSD, I believe it does some minor brake based torque vectoring. I remember reading some members posting how it was occasionally erratic mid corner in slippery conditions.
I could be wrong and it could just be over aggressive EBD instead!
Ahhhhhh, I remember reading about both those things too... Completely forgot about it.. Hmmm... I think you're right about this.
If I recall correctly, The Smoking Tire review from a couple of days ago also mentions this. I believe he said you can turn it off by disabling ESC so it lets the slip occur without trying to straighten it out.
whats the difference between the awd and the htrac awd in the G70?
Switched over to my winter wheels and tires recently and got thinking about the AWD system in the different modes again... Has anyone found anything definitive on how the G70 system works?
Even with the LSD, I believe it does some minor brake based torque vectoring....
And For a Sportier Drive
For those who want a little more performance, there is the Genesis’ sport mode. It alters the default power split to 20:80 front to rear that lowers to 10:90 during aggressive cornering. Working in conjunction with Hyundai’s Active Cornering Control (ACC), handling is further enhanced as the car will brake the inside rear wheel while accelerating out of an apex.
Winter Testing the Hyundai Genesis H-TRAC » AutoGuide.com News
Bringing this thread back to the top. Page 2 has interesting information about how torque distribution changes front to rear depending on drive mode and driving scenario.
so does the 3.3t g80 have the ability to send any power side to side, in the rear? or front? or is it only front and back power splits? Or is it just brake based side to side?
Brake based. Only way to properly send left to right is an active differential.
Front back. However, you have ESC which can apply braking pressure to an individual wheel to help reduce wheel spin iirc on how that system works.
Hello all, installing the snow tires for the first time on my G70 2.0T all wheel drive, first putting on the rear wheel, when off the ground the wheel would not free spin (was in park with the parking brake applied), next moving to the front wheel, this one would free spin as soon as it was off the ground, is that normal with the transmission in park ? Thanks !
