WYB: struts/shocks/springs from 2011/2012 Genny sedan
NJTom
Central PA
Hello All, I have an early 2009 Genesis 3.8 and as you all know has a jittery suspension. I'm looking to upgrade the sway bar to the 2012's hollow bar which I'm assuming will have to be purchased through the dealer for about $125.
I'm also looking to upgrade to a newer 2011/2012 suspension that someone may not need anymore since they upgraded to a coilover system.
Please send me a PM or email to let me know what you have. Please include approximate mileage and condition. I would prefer someone local to NJ but not necessary. Also, how much you are asking for the four corners.
Thanks,
NJT
jalanjalan: I saw your posting. I'm curious if the R-spec suspension would overall be an improvement over the early 2009 suspension. I'm concerned the jittery-tightness would still be as uncomfortable.
Under the "suspension" section I asked that exact question if someone else has done this comparison.
http://www.genesisowners.com/hyundai-genesis-forum/showthread.php?t=11237
The topic switched to the rear sway bar and I never really got an answer.
Can't say. Can guess : higher spring rate and stiffer dampening on rspec items seems likely :)
All, I'm bumping this request because I'm still in the market to anyone with a 2012/2013 Genny that upgraded their suspension with an aftermarket and want to sell me the old system.
I have a early 2009 and it is starting to get to me. I don't have the money to get a new system.
Thanks.
If you happen to get a bite I'll buy your 09 suspension I just need it for R&D
All. I'm still in the market to purchase someones 2012-2013 suspension if they switched to another system. Looking to upgrade from my 2009 which is really starting to annoy me. Thanks.
When I upgraded my 2009 to 2010/2011 specs, I purchased 4 springs, 4 shocks/struts, and rear stabilizer for about $1000 here:
www.newhyundaiparts.com
I got an independent suspension shop to install them for about $600.
If you can't afford that, I would go ahead with just the 2012 rear stabilizer first, as it might make enough of a difference to make it tolerable. Obviously, tires that rate high in "comfort" are a must also.
Mark: thanks. I recently switched to purecontact tires and that has helped some. I can't afford to pay $1000+ at this time. I'm hoping someone has changed out their suspension, with low mileage, and would want to sell it to me.
Still looking: If anyone has switched out their 2012-2014 Genesis suspension for an aftermarket coilover system (Megan, BC, HSD) and want to sell me their OEM setup, please send me a PM.
Please include the year, mileage, V6 or r-spec, where you live and how much you are asking.
Thanks in advance! Tom
Bump to top. Actively searching to upgrade my 2009 suspension. Thanks.
i have just switched to air ride on my 2012 gen the car only has about 25 k on it so its still fairly new what were you looking to pay ? if you want a faster response send me a text 480--200--7661
