Retro-fit Lane Change Assist?
OneFunGenesis
<- Runnin' on Empty
Rochester, NY
As most of y'all know here, the 2009 Genesis does not have lane change assist...why...idfk.
Anywho, is it possible to retrofit lane change assist from a 2010 into a 2009? I would assume it's just a module in the stalk or column. Any insight on this one all?
Thanks
OneFun
Is there an online wiring diagram system available for our cars? I did lots of retrofits with my previous car, but the key was availability of the wiring diagrams. With the WDS, we could figure out the differences between model years, option packages, and interconnections between systems.
For the LDWS, the key components are probably the camera/sensor on the windshield, the main control module, and the switch. It may take a software configuration change to tell the instrument cluster display to me LDWS aware.
I feared this would happen.
It isn't the LDWS I am after. It is the lane change assist...the three blinks of the turn signal when you hit the tug lights once...follow?
I knew that would be the misunderstanding lol
On the 2009s at least most of the front lighting - including the basic turn signal function - is controlled by the "Front Area Module" electronic box located in one of the black plastic boxes under the hood. If I remember correctly it lives in the passenger side box closer to the firewall. The "FAM" as it's abbreviated in Hyundai's literature is one of the largest modules in that box; it's held down by a "bail" style handle.
I don't know if later model year FAMs are compatible or not. They are expensive though.
mike c.
Not if I go to a junk yard and just rip it out :D. And how do I find this out? Part numbers 09 to 2010? lol. I know they'll be different.
Do I visit my friend who is a Genesis Tech? I assume he would know lol
So do you want to defeat this feature, or add it. Not clear to me.
Personally, I don't like the continued blinking after a quick signal for changing lane. I do this as a courtesy anyway, just one blink not asking but saying I am changing lanes. This prolonged delayed blink still makes me check to see if I have actuated (clicked) the turn signal.
Oops, my bad. Still, the same question applies... Have you seen any references to an online wiring diagram and online parts database for our cars? These are the resources that I have used for retrofit projects in other cars. I am new to my Genesis and this forum, so I have not found all of the resources available on the Internet yet.
A parts catalog will quickly isolate part number differences between model years. That can tell which range of parts might have the features you are looking for.
I find that feature to be a little "too short". Three blinks is better than nothing, sure... but I think it should be exteded to four or five, in my opinion.
I hardly ever use it.
HMAService.com is the place you would find that information, if it is available.
Good luck!
Thanks. HMA service does not play nice with my browsers so that site is kinda junk to me.
As to the lane change assist...I want to add it, yes. The 3 blinks is perfect for me and is a feature I use very often in my parents cars. I know there is a module to add this A/M but I am quite sure it is bulky, expensive, and keeps it on for 6 freaking clicks haha.
Any help is appreciated.
Agreed! not sure whos worse... the "q-tips" who cant see over the steering wheel anymore, or the 16yr old with a fresh, new license.
If you move to Florida you will never have to use your turn signals again. I'm pretty sure there is a law in Florida that says it is illegal to use a turn signal.
LOL. Absolutely. Some of the worst drivers known to man live in Florida. Try driving around in South Miami. Not only does it feel like your in a foreign country but the drivers down there have to be some of the worst in existance.
:welcome:to America. First learn to speak English, and second learn how to drive.:eek:
No, I believe you're thinking of California, where every car is the only car on the road.
It would be much cheaper and better just to install Android phone in a car dock on the dash and use iOnRoad Augmented Driving application which has a line departure feature as well as a close-up warning.
bumping this super old thread to add to the fail
I was reading the shop manual for the 2011, and it mentions LDWS, how to calibrate it etc. I found lane cameras from 2013 for about $130 on eBay, they would go left of the rear view mirror. This, and the fact that the engineering menu and the 2013+ cluster I have installed mention LDWS, I was intrigued.
Checked my car under the front part of the headliner, well guess what, there is no unused harness in there or anything. Guess there will be no LDWS for me :(
