Rudderman98
Got 50 miles on the Bridgestones and the pull is gone! Drives straight as an arrow. I'm sure the alignments helped too.
Problem solved.
Problem solved.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Problem solved.![]()
Awesome to hear RudDid you have a 2 or 4 wheel alignment done? My car pulls just a tad to the right, so I was going to get a front wheel alignment done and skip the rear wheels if it wasn't needed.
Not the kind of 1st post I imagined having nor wanting on this vehicle ideally :-/
Just purchased a new 2013 Genesis Sedan 3.8 this past Saturday. Car has barely 100 miles on it, and it already pulls to the right. Never hit anything, check tire pressures, drove on different highways and different lanes (i'm predominantly in the far left lane) all had the same results...pull to the right. I even overcorrected and let the car start veering into the left lane, hands off the wheel, within 10 secs...guess what I was heading right back towards the right. Funny cuz the test drive vehicle didn't seem to exhibit the issue and the only reason I took delivery of another one that was sitting in the back (that I never test drove) was cuz we had found it was cheaper by $1000 since it was sitting on their lot longer...same car/trim/color.
Glad I'm not the only one or its just not me being anal so the dealer can think i'm crazy. I already reported it and the service mgr told me "Well we usually like to wait till the vehicle has at least 750 miles on it before we assess"... What!!! well whatever...I drive 100 miles back and forth a day to work so I made an apt for next week (this week was jammed already) I definitely have over that many miles by then.
I also notice a little jutter when braking firmly within the 1st 100 miles as well which I also let them know about. Geez I really hope I didn't end up with a lemon or forever problematic like some I've read here and made the right choice over an accord.
Have the dealer check/adjust the alignment. Then test drive. If not corrected have dealer swap the front tires right to left. If not corrected then swap tires on front to back on the right side. test drive. This process should show up an alignment problem and or a tire(s) with radial pull.
Do you mean is it normal to get a free loaner when your car is in the shop? It depends on the dealer and the nature of repairs. Usually, they are not required to, but some do it depending on whether the customer demands it.When I took my 2010 in for the brake cleanse, I asked for a printout of the previous service. I recently bought the car used and it the original dealer was the dealer that serviced the brakes. I found much to my surprise that he had done two 4 wheel alignments in the year prior to my buying the car. I also found that all of his services and my service included a line called "rental car". Mine was under warranty so I didn't pay it but I also didn't get a rental car. Is this normal?
Since it is a Genesis 4.6, I assume you bought the car used. Technically there is no Lemon Law for used cars in any state that I know of, although there may be other possible legal ways to get restitution.I'm now in the same boat as alot of you...
Was driving recently and decided to take it to good year for an alignment. I got a call from them and they told me that the vehicle could'nt be aligned due to it needing a new camber kit. I knew this obviously wasn't the case because the way they were set, you can only adjust the toe. SO I told them not to touch it and to give me a print out of what was off. The camber on the driver side was way off.
I work in the auto industry so I know a bit about cars. I had a mechanic put the vehicle on the lift so I could check out the tires. No uneven wear. The kicker about all this is that I purchased this car 4000 miles ago.
I take it to the dealer and tell the service guy that I want an alignment. He said that wasn't a problem. I told him that I had taken it somewhere else and that they told me I needed a new camber kit and that it couldn't be aligned. I also told him I got a print out and the camber on the driver side was way off. He said that they would not be able to do things correctly because they don't have correct specs etc. I told him that I would be fine with everything as long as he didn't blame the alignment on my tires as they were not showing any uneven wear. He said if he can't align it then I would pay nothing.
About two hours in the waiting room a tech super comes up to me to let me know that my tires were bad. I told him the convo that I had with the writer and he said I understand but it is what it is. I said I just bought this car from you 4000 miles ago, it came with brand new tires. I checked them for uneven wear yesterday and there was none. He said that they must have a defect and that he would see about warranting them out. I told him that I didn't feel comfortable talking to him anymore as he had already tried to deceive me with the tire situation. I told him that i would pay for the alignment but that i want a receipt with recs for new tires. I would go and buy new tires, come back as soon as that was done as it will still be pulling to the right, he can rec a new spring, buy it from them and install it at my shop. This would be receipt number three without it resolving my issue. After that I could seek a lemon law lawyer, contact consumer protection and the bbb. Shop foreman comes out with a younger gentleman so he can sign me up for a rental, its been two and half days and I haven't heard from them. I will keep you all updated..
Good luck to all of you out there having the same problems as me
Thanks for the info Ron. Sounds like I'm almost helpless. Sucks I paid for an alignment that didn't correct anything. I have my specs of my 2nd alignment attached. I can't find the 1st alignment specs, but if I do I will post. Sorry it's so large. I'm unable to attach the pic due to pic size (surprise!)
