Just bought one of the last new Canadian 2013 Genesis Tech models
I have a few questions please:
The suggestion elsewhere to use mode and dual together to change temperature from Fahrenheit to Centigrade does not work on this model... any suggestions
I expected the iPhone 5s Music to stream wirelessly or via bluetooth as it does on my wife's 2013 Santa Fe, but so far it only works using the Genesis supplied cable with an Apple adapter from the earlier iPhone connector to the small 5s charge port
The 5s iphone connected to the cars USB port in the arm rest box gives an error message ... format
I read in one thread that an upgrade may be available
The trunk unlock seems to be limited to only the key fob or using the drivers door switch. no ability to open at the trunk itself??
Braking creates a slight shudder through the brake peddle, I am taking it back to the Dealer to have them check it over
I appreciate any help on the above
Thanks
Derek
Thanks
Derek
