daviderle
- Nov 17, 2008
Indeed, the 4.6 also has the same setup, just in case anyone is wondering...
The small open intake is fed from these scoops, while the air door is fed air from inside the engine bay, like so:
I agree, the air door may be only relevant for WOT or low speed operation, but once highway speeds are reached, there should be sufficient pressure build up in the air box, adding to the magnet forces which may prevent the door from opening at higher speed.
i.e., if the flapper/air door is removed, it actually may have a negative impact at highway speeds, which may impact cabin noise as well as air intake pressure which may affect performance, MPG among other things that we do not know about (yet!)...
As a summery, at this point we may have several potential solutions to try 'fixing' this issue:
1 - Reversing the magnets, to weaken the door force.
2 - If that is too difficult, one could try 'felt' / tape to weaken the door force.
3 - Remove the door all together.
4 - Implement a custom CAI / Cold air intake solution.
Again, if you do not have dead pedal issue, it may not be worth trying any of these things (i.e. "if ain't broke do not fix it"
Just my two cents...
