The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
OK, I give up. Why do you need to know where the turn signal relays are located on a brand new car under warranty?
I have looked in the manual and in the fuse panels, but can't seem to find the relay for the turn signals.![]()
I went through the service manual cover-to-cover and nowhere do they actually say where the relay is, or even if there is one.
Are you referring to the manual that came with the car, or the online shop manual?
I am going to call the dealer to see if they might know if there is a relay and if so, where it is located.
It wouldn't surprise me if they didn't even know, since the car is still pretty new.
Thanks for all the replys everyone![]()
When you put on the flasher, you can here the realy click or is that a speaker turning out a relay sound?
Just a ting to look into
CIAO
To scottdk: I can tell you for sure that load equalizers will be required for LED replacement of the rear turn signal lamps. It's not a problem; when you pull the plastic socket and OEM bulb out of its housing, you'll find a couple of inches of lead wire to which you can attach the equalizers. The fronts, however, are going to be a problem. Not only do the front signal bulbs have the funky, dual-contact, BA15d base (more common on combination tail/turn and sidemarker/turn signals), but the plastic bulb socket, itself, is not attached to wires. The entire socket and bulb come completely off the vehicle. The socket has two contacts, molded into the base, which connect when the socket is properly positioned in its housing. Therefore, no place to attach load equalizers. Since successfully locating the turn signal relay seems to be less and less likely, I've pretty much resigned myself to go with incandescent stealth bulbs in front.
