Bluetooth Issues
Rotary15
Just purchased a Genesis signature package and I am having a lot of issues with bluetooth. My phone will pair very easy with the car. The issue i am having is once connected the car the first few call I make work fine, but then once I try to call out it will automatically send the call to private or mobile phone and not handsfree. Sometimes i can manually switch to handsfree on the phone or screen, but other times it will not switch or allow me to make a call at all. Just wondering if anyone else is having this issue? Also i do have a iPhone 6.
Thanks
Are you using the voice command or trying to make a call with the actual cell phone. I have no issues when using the voice command.
It is when I am using my phone to make the calls. I will try the voice command and see if that works. Just have always used the phone in other cars with bluetooth.
Thanks
Other posters on this forum has had the same issue. If you use the button on the steering wheel, your problem should go away.
+ 1 - don't dial from the phone!
