Uniq Performance Rigid Collars
All I say, if anyone does not notice a difference, then the collars where not installed correctly!
I can not speak for the V6, but for the 4.6 and R-Spec the transformation was a significant ride quality, breaking, steering control improvements, which I have tried to describe in greater detail in several posts in this thread...
Amartz, is there any way you can take a video of driving on a bad road, prior and post collar install?
I wish I did that myself, as it makes it so much easier to document The results rather than trying to explain the ride quality improvements...
I'm definitely in then. Just wanted to make sure it wouldn't make for a more stiff ride. It sounds crazy because this car is definitely smooth, but on certain larger bumps or cracks it bounces upward hard. I'll order the collars and see what happens!
Thing is, I think it does a pretty good job now as it is, on bad roads. I wonder what I would try to capture in a video that would show the difference? When I talked to the fellow in Canada, he told me these were designed origianlly for the 2012 model year, and figured out later they work back thru the 2009 model year.
Driving on a Highway stretch that has rivets/joints/gaps, with cellphone recording video placed face up placed between right rear speaker and the sub woofer would be a good start...
Same phone setup on road with speed bumps driving around 5-10 mph, I would speculate, that the phone will shake / jump up and down, allot more before the upgrade and the movement will be reduced significantly after the install..
So many of us have mentioned the stabilization impact/planted feel on the rear end and it will be nice to capture / document if you can, as I think in this case a video would be worth more than 1000 words ;)...
I just got an email saying my collars are on the way. I'll try to figure out a way to get some before video.
[YOUTUBE]zWyUD6UXfog[/YOUTUBE]
Uh oh. That video is REALLY upping my expectations.....
Consilius
Excellent video you found :)
Really shows us better in depth what these bad boys can really do and how they work :)
Just ordered a set for my coupe from Unique Performance in Canada.
Depends on how it turns out I will get another set for my sedan.
I like the idea behind the ridgid collars. Setting up the geometry correctly is important, of course, but I really like the idea of inserting a softer, deformable material between the subframe and the body. The quality of the vibration transmittted to the driver through the body has to change when passing through soft aluminum, rather than going directly from steel to steel. I can see how this softer material between the two steel surfaces would dampen sharp impact vibrations.
I'd like to go through with this mod, but I'm concerned about the kit provided by Uniq. It looks more like a set of washers with extensions, and not what's described in the video. The video shows a collar design that includes a flange that goes between the subframe and the body, while the Uniq kit shows a collar design with a flange that goes between the subframe and the bolt head. Its the "squishing" of that flange between the subframe and the body that's supposed to eliminate the "spring effect" described in the video - if the flange isn't there, there's no reduction in the spring effect and no isolation of vibration.
I can see how isolating the bolt head from the subframe would be helpful, since the bolt is fastened to the body, but there's even more contact directly between the subframe and the body. It seems to me it makes more sense to have the flange between those two parts than between the bolt and the subframe (since you can't have more than one flange). Maybe buying the Uniq kit and adding my own aluminum between the subframe and body is the way to go.
Y'alls thoughts?
They will fit between and not as depicted in the Genesis Coupe video.
The key is to explain exactly where the collars are installed, which have been mentioned earlier in the thread (In summery: 6Rs in the front, 2Rs in the back nearest the bumper, F goes in the passenger side and the unmarked U / thinnest goes on the driver side of the remaining bolts),example;
F-BUMPER-F
R O-- - --O R
R O-- - --O R
U O-- - --O F
R O-- - --O R
R O-- - --O R
B-BUMPER-B
(F=Front, U=unmarked collar, F=Marked collar, B=BACK)
Well, I finally got mine installed Saturday! First impressions are good, it does seem more solid, without being more stiff or harsh. I don't know that I'd go so far as to say it "transformed" the ride, but then I always thought the ride and handling was pretty damn fine already!
The tech let me watch over his shoulder (figuratively speaking, since it was up on a lift). The placements of the collars did come out a little bit different that the diagram that was posted here. There were two bolts on the front sub-assembly that the fitting was so tight that it required the thinner collars, but they weren't quite the ones listed here. Redoing the chart, what he installed was more like:
F-BUMPER-F
R O-- - --O R
U O-- - --O F
R O-- - --O R
R O-- - --O R
R O-- - --O R
B-BUMPER-B
In other words, the thin ones went in the middle pair of the six bolts on the front sub-assembly, not the last pair of bolts on the front sub-assembly.
Definately get a four-wheel alignment done immediately! He pulled it around on the alignment rack when he was finished, and *everything* was way out of wack! The geometries had all been changed. Not surprising since he was prying on the sub-frames with a crow-bar to get the bolt holes to line up so he could get the collars in. He took his time, and fussed with the alignment until it was just so. Even had me climb up and sit in the drivers seat to see what it did to the numbers, and to double-check the steering wheel alignment. That's why I'll pay the dealer rates for something like this, attention to detail. Plus the tech is a bit of a motor head himself, and was real curious how it would come out. The results put a big smile on his face, and a big thumbs up! but then, he doesn't drive it every day. I have a few before videos, and I'll try a few after videos. I don't know if the difference will come out clearly or not, it's kind of a subjective feel kind of thing.
But there's at least one curve, in a valley, over an older bridge, where if you take it at speed, you usually have to allow for some lane drifting, because of the rough surface. I tried it once this afternoon, and it stayed right in my lane, didn't drift wide at all. Wound up nailing the gas half way thru the curve, because I didn't get the usual drift. I'll try to get a video of that tomorrow also. Oh, and my LED backup lights just came in. Maybe get them in tomorrow, since it's a holiday for me, even though I have to go into the office for a couple hours in the morning. Starting to feel like Christmas all over again here!
Well, uploading a couple of mp4s didn't work so good. Any suggestions?
So you're saying that the flange on the Uniq collars goes between the subframe and the body?
If that's the case, how does the collar installation improve the subframe alignment? The Uniq collar doesn't extend through the subframe mounting hole, so how is alignment improved?
Yes. However, if my memory serves me correct, 1 or 2 did not go between the subframe and the body.
Just ordered a set for my 2012 genesis sedan. Also ordered ark lowering springs. Hope the combination of the 2 give a sporty and better ride.
Ordered a blue set for my 2014 sedan 3.8 and installed this weekend in my garage. It took me about 3 hours start to finish.The front started easy on first 4 the last 2 close to front bumper had to fight. The 4 rear were easy i went off the link flynblind posted. Easy post to follow. Iam wanting to get the alignment done before i put miles on it. But riding up road seemed tighter but definitely not as harsh on bumps on my road..
