The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
im with mark 88 on this one...
Beyond the 3% energy decrease of ethanol, ethanol needs high compression ratio(16:1) ethanol engines to effectively release its energy. Ethanol used(not burned effectively) in low compression ratio(9:1 to 12:1) gasoline engines cannot release its energy effectively. I have many years EACH, comparing 10% ethanol blends to 100% gasoline(E0) for 3 cars, showing 8%, 7%, & 5% increased mpg with E0. All engines run smoother, quieter & with a trace extra low rpm torque......
In essence, this post proves that ethanol engine engineers & gasoline engine engineers know how to design their specific engines.
While alcohol allows a higher compression ration(sic), it is not needed to make use of the BTU's in it.
That's hardly a controlled test. Winds, weather, traffic, and the driver's expectations all play into it.
I don't know if you are referring to my post. However, if you are, then I think you should re-read my post. I have taken this same trip 10 times - repeat, 10 times - over 3 years. The results do not vary by much. I suppose I could go back and find the physical gas receipts with mileages on them to provide statistical proof, but this is not Judge Judy.
That being said, the winds, traffic, and my expectations would average out over 18,000 miles of interstate highway driving. The results were always the same. NON-ethanol 87 gas always beat the ethanol variety by at least 3 to 4 mpg.![]()
This doesn't surprise me, and seems consistent with what I've seen as well. What also seems clear is that whenever anyone posts their real-world observations about Gasahol er I mean e10, there are some very vocal ethanol-backers who are intent to try to somehow discredit that information. All I can say to the other forum members is, don't take my word for it, try it yourself. Try taking a round-trip and if you have the opportunity, try one half with e10 and the other half with e0 and post your observations.
Bad idea to use E10 one way and E0 the other way due to natural variations.
More importantly, as both an engineer and a gear head, I'm not interested in the hoopla over the good and bad of ethanol (food prices, starving people, etc. etc.). The real, provable facts from controlled tests is what I base my judgement on. And the facts are that you can expect about a 2-3% drop in mpg with E10 and about an 18% drop with E85.
Anything more is the variable introduced by non-repeatable "real world" operation.
So why don't real tests, run with EPA dyno's, get similar results when comparing E85 to pure gasoline??? If you are losing 10% of your mpg (or more) with only 10% ethanol, than a car with 85% ethanol would only get about 15% of it's mpg with regular gas.
Instead, E85 which has about 72% of the BTU's of E0 gets............................about 72% of the mpg of E0 per EPA dyno tests. Go figure.
By the way, are you using E0 one way and E10 the other way?? Lots of opportunities for variation based on elevation change and prevailing wind. directions
But as we well know, it wasn't just hybrids that had to have revised mileage. In fact, several of Ford's vehicles, as well as several as Hyundai's, had to revised because the as I understand it, the EPA wasn't testing the vehicles at all and merely defined the parameters of the vehicle test cycle. In fact, that was and is a big problem.
As far as the BTU energy, I'm not arguing the BTU energy, I'm arguing whether the tuning makes a difference, I believe there are factors in tuning which are affecting the mileage above and beyond the BTU difference between E0 and E10.
I suspect the engineers have got their computer controlled fuel systems (complete with knock sensors) well optimized.
