GenesisCaptain
- Aug 29, 2012
I think most manufacturers do not publish engine weight, so it is difficult to get an authoritative answer. But, if the 1st gen Genesis 3.8L V6 weighs 225 lbs. less than a nearly identical 5.0L V8. It is probably a reasonable assumption that most of the weight difference can be attributed to the engine. (Interestingly, the 2015 is a 400 lb. difference, but I think the V8 has heavier wheels and other equipment.) Therefore, if the smaller displacement engine with fewer cylinders is lighter, then it is probably reasonable to assume that the number of cylinders and displacement probably directly, proportionally affect weight. The wild card is the extra weight that the forced induction plumbing and devices add. But yes, for two engines of similar power output, I believe it is reasonable to assume that a typical FI engine is probably lighter than a typical NA engine.Do you really think these motors, with turbos, weigh less than the Genesis V8?
I thought you guys were all about justifying the use of a 6 cyl and a turbo in large cruisers. That's certainly what I thought you were trying to say.
The thread originally started with the comment that Hyundai is developing a turbo 3.3l engine for the Genesis. The leaked specs say that the engine will produce 27 more horsepower and 84 lb-ft more torque. Since they dropped 1/2 liter in displacement, it is probably reasonable to assume that it will be no heavier than the 3.8 we have today. And, the torque will come in way lower in the power band. That is almost the same torque as the current V8, so the car will potentially out-accelerate the NA V8.
If you had to have a V6, wouldn't you rather have the Hyundai 3.3l turbo with 380 lb-ft of torque at 1,500 RPM versus the 3.8l with only 293 lb-ft at 5,000 RPM?
Likewise, if you were choosing a V8, wouldn't you rather have something like the S550's blown beast with 516 lb-ft of torque at 1,800 versus the current Genesis V8 with 383 lb-ft at 5,000 RPM? Or, if you were going to "settle" for the wimpier Audi engine, that one is a full liter smaller than the Genesis V8, yet it produces 444 lb-ft torque at 1,500 RPM. The Audi engine probably is lighter and would accelerate the Genesis much faster than the current NA engine.
