Mark_888
- Jan 9, 2009
Mobil 1 has a couple of different motor oils that are specifically designed for motorcycles. Here are some of the differences between these and regular Mobil 1 for passenger cars (from the Mobil 1 website):I once ran Mobil synthetic in a sport motorcycle and all it did was get me burned out valves, eventually.
- In general, Mobil 1 motorcycle oils have additive packages balanced differently for motorcycle engine and transmission operation.
- For passenger vehicles, fuel economy and emission system protection are higher priorities. These require low phosphorus systems and the use of friction modifiers.
- Motorcycle oils do not require friction modifiers for fuel economy and for better clutch friction less/no friction modifier is optimum.
- Motorcycle oils allow the use of higher levels of anti-wear additives such as ZDDP (phosphorous).
In addition to the overall benefits listed above – specifically, high-temperature stability and low volatility/low oil consumption – Mobil 1 synthetic motorcycle oils also offer superior anti-corrosion performance compared to conventional motor oil, which is important in many parts of the country where bikes may sit in garages for several months of the year
