How to: Changing the key fob battery (Video)
PMCErnie
Ancient ‘steemed Member
Richmond, VA
Genesis GV70
Re: Changing the key fob battery
How long do the batteries last?
The battery for my Elantra is still going after almost 11 years. (but it only locks doors)
Too bad you didn't read this thread first. You could have done it yourself and had money left over for Starbucks.
One of my fobs, 2014 Genesis with 6300 miles died a few weeks ago.
Went to the Dealer yesterday, $6.38 to replace the battery.
Earl
How did you get a dealer to do anything for six bucks and change?
True enough but I would rather pay the little bit and not scrape, break or mess it up at this point.
Still got a Starbuck, tall, black, regular. No fancy froths for me.
Earl
Earl
Using a screwdriver to pry it open can deform the plastic seams a little bit, but a little sandpaper makes it like new again.
Pull the key out halfway & rotate to open fob shell - no fuss - no muss
See the video in the first post
Video worked great, glad I found it here. Thanks for taking the time to post! Regards, Inis
2012 Genesis, 4.6 L V8
The trick is to remove the key first.
http://youtu.be/uC7iIa6vwAU
DO NOT use this video to change battery. You will break off a tab. Instead, get a small straight blade screwdriver about as wide as the slot near the key hole. Place screwdriver in the slot and twist. Much easier and without risk of breaking the plastic.
https://www.youtube.com/watch?v=OsrB0TdTGCw
The above video is for the Genesis Key Fob and works perfectly.
I had this pop up on the screen the other day. Awesome feature. Because we were down at Key West I didn't bother changing it until we got back home today. The warning came on every time I shut the car off.
Yep the correct way to open the fob case leastwise on my 2016 Ultimate is to use the narrow blade screwdriver method, piece a cake!
