[KDMHolic] Storm Lowering Springs for Genesis Coupe & Sedan
KDMHolic
New Jersey
FOR GENESIS COUPE
BRAND: Storm Spring
ITEM: Set of Lowering Springs (2F & 2R)
DROP:
F = 1 inch drop
R = 1 inch drop
RATE:
F = 174.71 lb/in
R = 271.59 lb/in
PRICE: $328.99
** Specs and price is same for BK1 and BK2 **
FOR GENESIS SEDAN
BRAND: Storm Spring
DROP:
F = 1.38 inch drop
R = 1.18 inch drop
RATE:
F = 202.15 lb/in
R = 268.79 lb/in
PRICE: $370.99
** Specs and price is same for Genesis DH 2015+ **
** Storm has not done any testing on AWD DH yet. The springs will fit, but we strongly recommend to wait until Storm has test results on AWD application **
STORM SPRING does all of their designing, manufacturing, and testing on their own in South Korea and as of now, they are the only Korean suspension manufacturer that is 100% independent.
All of their suspension products are under warranty for 5 years and 100,000 km (approximately 60,000 miles)
Their lowering springs are made from 100% cold forming steel and are designed and manufactured to be about 20% stronger than factory springs and lighter and more durable than OEM.
Please PM me if you are interested.
You can also e-mail us at kdmholic@gmail.com.
Thank you for looking!
:grouphug:
How do I get a set of the springs for my 2015 Genesis coupe?
Any updates on the AWD application for the 2015 Sedan?
Team at Storm Spring confirmed with me that they have tested their springs on the AWD Genesis DH sedans and everything went smoothly. :D
Same specs and same price on the springs.
Message me or leave a comment here if interested.
Thank you for your patience.
Thanks! How are they with the 5.0 AWD?
i'm interested in a set for the AWD
So, these springs replace the stock springs leaving the stock shocks in place, correct? How will the ride be affected? Also, will the sedan springs work for V6 as well as V8 models and affect the ride height the same?
EDIT: Posting PM response here for the sake of benefit to all.
"The lowering springs are designed and manufactured to work on the OEM shocks.
According to our customers including a forum member here, ride will be a little bit sportier, but the springs will not damage the ride quality.
There are springs for the V6 and the V8.
Down height will be the same specs."
