rim size question with 4-piston caliper
Ghettosled
Lakewood, Ohio
I am looking to buy some snow tires/rims and was thinking about buying a cheap set of stock (used) 17" genesis rims. I saw a Genesis parked with said rims, but noticed not all Genesis' are equipped with the same front calipers. They had typical single-piston calipers. Will these rims fit over the larger caliper?
The Sedan Mando caliper is a little thicker than the Coupe Brembos, but some Coupes did run Musttang 5-spoke 17s for winter setups.
Worst case scenario the front would need a 5mm spacer.
