srobak
Former 2015 G80 owner - soon to be G90?
- Aug 2, 2015
- Location
- Packerland
You need a long slim Phillips screwdriver. That white plastic tube is where you adjust the low beam cut off. You can't miss it. Insert your screw driver there and rotate. Make sure the car is level and there no weight on it
Mine is completely different then. If I look in the tube I see the teeth of the gear that the motor uses to raise & lower... certainly nothing with a phillips head on it. This same gear is accessible from the back of the housing with an 8 or 10mm bolt head on it - I forget which. If I turn it - it will strip against the gear of the leveling motor. Back to looking for a way to adjust the sensor...
