Blue Link Apps for 15' Genesis
where do you setup on myhyundai.com ? Not sure I see anything that is close to a configuration screen.
First install "Bluelink Alert Services" App in your car. The log into MyHyundai.com on a Desktop (below features don't seem to be visible on a mobile device - at least not on an iPhone):
  • Click on "My Bluelink" on the upper right part of the screen:
  • You'll then see this screen where you can activate the 4 different Bluelink services on the bottom row (Location sharing not yet active, so it's greyed out):
The top row does not need the Alert Services App to be installed in car to work as those are standard, preconfigured Bluelink services.
Thank you. Never knew that was a link.
Did you install the Location Services app>
Yes - under the Bluelink App download in the car while it was connected to my home wifi network in my garage.
I actually used it when my car was at the dealer for a few weeks and I knew they would be moving it to a glass shop to work on the sunroof. I set a geofence alert and a max speed alert, so I knew when they moved it and that they did not take the car over 70 mph.
I guess it could also be useful if you have kids driving your car and you have some trust issues ;)?
yes I DL all the apps available in the car. was just wondering about the Location Sharing why it was all greyed out. this option reminds me of a car review back from 2008-2009 when the reviewers were all test driving different Genesis' and they could all see each other Genesis on the map screen. I always thought it was cool, but never saw this come of age. I'm wondering if this is what that Location Sharing is...
Sounds like it could be.
anybody out there experiencing no network connection? my bluelink was working perfectly fine the past couple months then 2 days bam! not working. looked at the car today and no 3g network. soundhound also gives me "network error"..
Just a note.. i called in and bluelink just sent a request to flash my lights which didnt work. They then told me they will forward the issue to their engineers to see what the issue was. They also stated it will take 3-5 business days. After i got off the phone i sat in my car for a little bit and play with settings in my dash oh and before i turned the car on i hit the eject button a couple times i then turned the car on and the radio seemed to do a hard reboot and when it did the network was back.
I dunno what i did or pushed but seems like a reboot is all it needed..
Does anyone know hot to make the radio reboot when needed?
It was mentioned and discussed here when it came out last last spring. Have downloaded it, but not used it.
Ksoze. Can you post some pics of your black / ivory Genesis?
Available on all other models except the most expensive genesis you can buy.
If you are referring to your 5.0, I can add that it's not available on 2015 3.8 Ultimate as well.
I even doubt that it's there for lower trims of 2015 Genesis, but not 100% sure. Could be 2016 MY update.
