Power to Dashcam G2
pmckechnie
Matthews, NC
Genesis G80
I know some of you have dash cams in their Genesis. How did you get power to them?
Thanks
PaulM
I don't have any from the install, it was so long ago I don't remember. I was installing the dashcam, hardwiring my Valentine one, and the laser jammers all at the same time.
Unplug the molex connector under the small removable panel above the rear-view mirror assembly. If I remember correctly, the black wire and one of the gray wires are your ground and switched power lead (turns on when the car is running, off when it's not). Looking at the plug-end of the molex connector, I believe these are the lower middle hole and the far left hole. Double-check with a voltmeter to be sure. This worked perfectly for my radar detector.
Tony
Thanks everyone. I have now got a plan. I'll let you know how it goes.
PaulM
Tony
+1
