Genesis 5.0 Wheels data
forzza1
Toronto, Canada
Genesis G90
FYI...
Front
Tire size: 245/40R19 - 94W
Rim: 8.5J x 19
Rim Offset: 40
Bolt Pattern: 5x114.3
Bore: 67.1
Rear
Tire size: 275/35R19 - 96W
Rim: 9J x 19
Rim Offset: 49
Bore: 67.1
www.wheel-size.com
Just to add to this the lug nuts used are 12mm x 1.5.
I researched this and realized they are not listed as after market probably due to the relatively new model and rarity of the Genesis. Strange as it may sound you want to get "Toyota" mag wheel nuts. I measured this with callipers and ended the Toyota are the exact fit in all respects. See here. http://www.ezaccessory.com/Toyota_Lexus_OEM_Mag_Lug_Nuts_p/98-0003.htm
If you want some really nice theft deterrent lug nuts, I highly recommend the Gorilla brand which is what I got. Normally you have one per wheel however these are for all nuts, look great and work extremely well. Available in black or chrome. http://www.amazon.com/Gorilla-Automotive-73633T-System-Washers/dp/B002807WQK
Midnight, thanks for the excellent tips as usual. Have you tried those yourself? I realize you said you measured them. Thanks!
Yep, fit like it was Hyundai brand off the shelf. Using the Gorilla version in black to go with my charcoal stock painted wheels. http://www.ebay.ca/itm/20-ALL-LOCK-...LS-RIM-MAG-LUG-NUT-12X1-5-BLACK-/161600324592
Yes those are the ones I ordered and using even though it says Mitsubishi. Obviously the thread is also the same as Toyota. ;)
Image here:
i64.tinypic.com/2h2k36v.jpg
