A SRI? Yes, the R2C, but as already discussed, the filter is horribly undersized, so you really are paying a few hundred bucks for the induction noise.
I don't think the R2C intake filter is undersized.. Mine seems pretty beefy to me.
When you calculate the filter media surface area of the R2C and compare it to the filter media surface area of the OEM panel filter, it is quite a bit smaller actually. Then you calculate the minimum required surface area to support the Tau throughout it's RPM range, you will find the OEM panel filter is *just* sufficient enough. So to go any smaller does actually choke the engine. Tuned 4.6s with R2Cs experienced hesitation caused by fuel/timing cuts when the MAF volume did not meet the demand, whereas tuned 4.6s with a factory air box, or in Tailwalker's case, a tuned 4.6 with a gigantic filter, did not experience the same cuts.
For a good example, look at some of GM's LS engines, while they do not move as much air (cubic inch for cubic inch) as the Tau, look at the aftermarket intakes that give them the most power over stock. Time and time again you will find it's usually an OTR (Over The Radiator) with panel filter(s) or a large oval filter. Oval shape gives it significant more filter media surface area versus conical of the same "size".
Rey,
I proved in a previous thread "Rspec on Dyno" that adding MSA cat deletes added 15rwhp gains! After another Dyno, proved CAI added another 15rwhp gains. Total real world back to back to back Dyno runs showing each improvement. This was insane and amazing for the money. Our cars are so restrictive with the 4 cats and huge maze of air box & filters.
Each run was cooled off from prior run though so no heat issues. And the hood was up to draw in cool air.
I am going to have Abel work up a cold air box.
ABEL Racing designed and installed this Cone Air Intake (CAI) today and we dynoed before and after results. CAI gives 15 Wheel Horsepower (15whp).
* removed stock airbox assembly
* add CAI
We did dyno with MSA cat delete pipes for another 15whp gain.
Total, 30whp gains is amazing. The car is stock quiet at idle and normal driving. When you really put your foot in it, you finally hear that great V8! I am surprised how perfect this set up is. No droning in car or funny noises.
PM me for your ABEL Racing CAI kit!
