The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Thnx ntx_v8 for instructions with pics. Have you changed the cabin air filter? Any tricky Hyundai engineering in the use of clips or fasteners to be aware of?
Noted and thank you again.
Cabin filters and air filters are the easiest DIY items, although the Genesis seems to involve a little more for air filters.
Sheesh' whatever happened to spin the wing nut and lift off the cover!! LOL
It's very easy. Loosen the two bolts, the bar comes out. I think they are 12mm if memory serves. So easy I let my neighbor's kid do it.![]()
Posting this a second time since this thread has directions. Hope op will edit to give this link
Here is the filter for $21 https://www.amazon.com/WIX-WA10163-Filter-Panel-Pack/dp/B019HXX4NK/
This is for the 2015 Hyundai Genesis 3.8
Amazon has it marked as incompatible and I sent a correction to them. They probably wont fix it.
Bumping an old thread. Just picked up a CPO 2015 3.8 coming from a 09 4.6. Was looking under the hood yesterday and noticed the stupid brace over the air intake. Came here to see if that in fact must be removed to change it, what a dumb design. And it's not like the V6 engine compartment doesn't have plenty of space to spare up front. Could've just moved the thing over 5" and ducted the inlet a bit farther.
To add to this rant about the poor design decision about the airbox and chassis support location, you will have to remove both of those parts just to change out the headlight bulbs since the air boxes block the headlight bulb opening.Bumping an old thread. Just picked up a CPO 2015 3.8 coming from a 09 4.6. Was looking under the hood yesterday and noticed the stupid brace over the air intake. Came here to see if that in fact must be removed to change it, what a dumb design. And it's not like the V6 engine compartment doesn't have plenty of space to spare up front. Could've just moved the thing over 5" and ducted the inlet a bit farther.
The EPA is making life expensive for automakers. They are using expensive technology to make their cars fuel economy the best it can be. Examples are: Direct injection engines, the ability to cutoff some cylinders when power is not required, aluminum, magnesium and high strength steel for body parts, entirely closing the bottom of the vehicle for improved aerodynamics, turbochargers, taking out spare tires to reduce weight, electric steering, low rolling resistance tires, etc. If a better air filter exists they would be insane not to use a cheap fuel economy enhancer like that.
If you think you know better than everyone, go ahead and waste your money if it makes you feel better.
Automakers have to find solutions that increase gas mileage, but at the same time reduce the environmental impact of the engines as well. Performance air filters only solve one of those problems, better fuel economy.
