G70 2.0T Advanced Active Engine Sound
TheRick
Hello,
I have a 2019 Genesis G70 2.0T Advanced. I want to know if this model have a Active Engine sound for the exhaust. Can't find any information on that.
Thank you
Eric
Hello,
Thank you
Eric
Not sure if the base model has it.
It does not have it. It is in the Elite and up.
Ok thank you cza11
Ive got an answer from a Genesis representative and he said all G70 model has it. But how can I have access to it ? Do I need to go be in sport mode ? Seem to can't find it in the menu.
Somebody know where I can find it on those model ?
Thanks
Ok thank you very much, Im gonna check it. And let you know guys :)
Thanks for all the help
Its look like I don't have the option. I'm gonna check with Genesis if maybe its not a software update that need to be done20181010_180352.webp
I don't know if you read french, but thats the message Ive got from Genesis :
Cher Mr. Brideau,
Merci d’avoir contacter Genesis Motors Canada.
Tous nos véhicules Genesis G70 sont équipés du Active Sound Deign qui augmente la sonorité du son de l’exhaust à l’intérieur du véhicule.
Si vous avez d’autre questions, n’hésite pas à nous contacter.
Bien à vous
Soudabeh
Customer Experience Team
Its said all the Genesis G70 are equipped with the ASD.
Probably not only the representative that sold me the car but there employee also :)
Thank you
I can't tell the difference between any of these sounds. How about anyone else out there?
Me neither. I was playing around with it the other day, can't tell a difference. Though, I do have an aftermarket exhaust, but it's not a ton louder than stock. 🤷‍♀️
Same here. Decided to try playing with it the other day for the first time, I honestly could not hear a difference even between "enhanced" and "off."
I've tried to feel the difference but I was unable to hear anything too. I thought it was because my hearing loss but now I can see I'm not the only one.
It does appear to be hard to hear, I agree.
Is it because the subwoofers are part of the engine sound system (if they are)? If they are too limited, or not working, the sounds and vibration disappear.
Try it at WOT in sport mode and you should hear it. Not sure if stereo volume impacts it or not, but the one time I did play around with it, I had the volume around 15.
It was discussed in another thread, but the noise isn't really added at all points in the RPM range and I believe anything short of sport limits the effect as well. It's largely there to make you feel like you have a race car when you mash the pedal
Oh dang, I didn't know that. I'll have to try it again, I'm curious now.
I can attest to the fact that volume knob setting has no effect in volume of active sound. ASD setting — Normal, Enhanced, etc. — does have a subtle effect. Try switching between enhanced and off. You’ll notice the difference and will be able to discern whether you like the artificial sound or not. Loudness increases with RPMs, not throttle input.
