mtrot
- May 20, 2013
- Location
- East Texas
- Genesis GV80
Any thoughts on engine cleaners for the 4.6L( or other displacement) Genesis engine? Has anybody used them, and what were the results?
My 2012 Genesis 4.6 now has 120k miles on it. The issue is that, after shutting the car off after driving it and letting the car sit for around 10 minutes, THEN the engine will sometimes die after cranking it back up. It will run for a couple seconds and then, as the rpms drop to the proper idle rpm, the engine will die. Now, if I then just crank it back up and hold the rpms at a higher level via the gas pedal for a few seconds, it runs just fine after that. This problem only occurs if the engine is already warm. Once the engine has been running for a minute after starting it, the car runs like a scalded cat. When starting from cold, the system automatically holds the rpms up high for a minute or so and the engine doesn't die.
I recently installed new spark plugs and a new air cleaner, so neither of those things should be the cause(it was exhibiting this dying behavior before I installed the new plugs).
