The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Map6. Try 5psi across-the-board so there is no taper at the top end or go 5.5psi for the lower rpm or something similar to that!I’ll try that. Most seems to be on the start. 60ft time is 2.27 330 ft is 5.86 1/8 mile is 8.80 @83.49.
Is there a way we can get more boost in 1st & 2nd?
Well with Dragy my 0-60 time on map 2 is 5.31. On map 0 stock 5.73
Temp 105 humidity 35%
Managed a 1/4 mile run at 13.46 @ 105.36
Having lived in the Portland area for so many years and having cooler temps I’m guessing these high temps are killing my times.
Seems like there is so much lag out of the hole even with launch control
3.3Is this the 2.0T or 3.3T?
Look around the Stinger forums and you'll find plenty of guys between 5-6 secs even with LC.
You have to find the perfect way to launch it and then it becomes more consistent!
That would be the educated guess but that's not the case. All the stars have to align to get a proper launch.It's a 4.4-4.7 second car stock. In extreme heat, 4.8-5.... 4 flat with Map 2. The stinger is close but a bit heavier.. I could see a worst case of 5.2 I guess... Getting 5.3 with Map 2 just doesn't add up.
How do you launch in different ways with LC?
I’ll try a few different ways to launch in the morning when it’s cooler (if you call 82-84° cooler).It's a 4.4-4.7 second car stock. In extreme heat, 4.8-5.... 4 flat with Map 2. The stinger is close but a bit heavier.. I could see a worst case of 5.2 I guess... Getting 5.3 with Map 2 just doesn't add up.
....he said wet dayThat would be the educated guess but that's not the case. All the stars have to align to get a proper launch.
Let your wheels slip a little.
On my 2.0T it took me forever to get to 6.0 from almost 7 secs and once I figured it out, I could consistently get 6.1secs.
It takes a lot of practice. Try on a wet day. That always works out for me.
Is that with roll out? I’ve read that can be up to .3 secInteresting. As a point of reference, Road&Track ran 0-60 in 4.9, 1/4 mile in 13.4@104.8 stock in 100+ heat. I would think Map 2 would improve on that significantly..
Feels like something is wrong?
^ I will say this again...and I know what I’m talking about...tinkered for over 5 months.
Map 2 needs good 93 octane. You can run with less...but don’t complain.
Map 3 needs 96...99 is optimal. I run 99.
Map 5 loves 103-106 octane.
No idea. I have various Logs posted on the N54Tech board.Beefer, how much does boost or timing increase on average using 93 octane on Map 2? Do you have some graphs you can post?
