Golfnut4211
- Apr 24, 2019
- Genesis G70
A month or so ago I posted a thread about my front sensors not working. The advice was to take it to the dealer as no one else seemed to have my issue. To recap, my front parking sensors will not work unless I stop, put the car into reverse and then back into drive. The sensors will then work perfectly. I sent the car to the dealer and they found no fault. To thicken the plot, they tested 3 new G70's on the lot and discovered that they behaved the same as mine. In their wisdom, they decided this must be normal.
It is far from normal if someone has to shift a car into reverse to get the front parking sensors working. BTW, this problem only developed when the car was 4 months old as for the first 4 months they worked as they should. The reason for this new thread is to solicit some response from the community. Who out there has the same problem and who of you have front parking sensors that work the way they should? Thank you
