Platgen
- Jul 29, 2010
Any advice on why the yellow lights on driver's heated switch keeps flashing. The car is a 2010 base Genesis. In particular, the most right yellow light keeps flashing. The other two yellow lights are solid. The lights cannot be shut off once the switch is pressed without shutting off the car. I do not think that the seat heats up anymore.
The passenger's seat still works properly. All three yellow light up when the passenger heater switch is initially pressed. If the switch is pressed again, only two lights are lit. If the switch is pressed again, only one light is lit. The passenger seats correctly lowers the heat after each press of the passenger's switch.
I will be bringing to dealer but would like information if anyone has experienced this problem.
Thank you.
Thank you.
