Toddasaurus
REEEEEEEEEEEEEEEE!!!!!
- Feb 18, 2018
- Genesis G70
Well if it is these are the cars that use the same brake lamp switch so possible donor for the wiring connectors and could use the switch and dissemble and use the connector only to build the lead.
So I know this reply is too late, but I figured I'd still show what I found.
Solid dark green wire on the brake pedal harness plug...
Found a similar dark green wire in the ECU harness plug....
And this may be the same wire further down the harness leading into the firewall...
Anyway, long story short, I think you're right @FastEddie , I bet the brake snip wire is that green one on the brake pedal harness plug. I'm considering going to my nearest junkyard for a donor plug to make a custom harness; but, I really have no idea where I'd find a suitable female connector. Maybe the female end attached to the brake pedal assembly is able to be disassembled...
