Walnut blasted my intake valves
JgenG
Finally got my intake valves walnut blasted. Did it after 100200 km and the carbon build up was pretty significant.
How much did it cost?
What shop in TO if I may ask? I need a good referral that is a non hyundai dealership for my Genny. Pls PM me if you can thank you
duplicate post
What grade of fuel do you use?
You had a lot of carbon for only about 60k miles, got me concerned about my valves.
Yeah that has me a little concerned as well. I've got a long way to 60k but not looking forward to pecan blasting...
I will remove my intake manifold and use CRC carbon cleaner that dissolves carbon to clean my valves/intake chambers with a brush added to scrub the stubborn areas. However, walnut shell basting does work well if I was going to pay someone to clean my valves.
The valves seem pretty easy to get to on our engines, however I may have to manually turn the engine to keep the valves closed while cleaning to prevent carbon chunks entering the combustion chamber. I am curious if the engine has to turned during walnut blasting.
However, after looking at this video I may just a use brake cleaner to breakup the carbon since it did better than CRC on cold engine parts.
I use the mid grade fuel . 89 octane
Thanks. I do not know if the grade of fuel correlates to the amount of carbon build-up, but it helps me compare later on when I inspect my engine. I was going to wait until 100k miles, but I may just clean my valves at about 80k miles when I change my spark plugs since it easier to turn an engine when the plugs are removed.
One more question, Are you doing city driving or highway? Or both? I apologize for the questions! Just trying to get a feel for things. Thanks.🙂
I do both about 60% city 40% highway
