LoLaWy
- Feb 20, 2019
- Genesis G70
I’m having an issue with my transmission, started to notice it since the car had about 20000 km on the clock (car now has 52000 km)
the car doesn’t smoothly downshifts during normal soft braking or in stop and go traffic or at a traffic light
The downshifts are very noticeable and that makes the braking experience unpleasant. Especially when I’m braking very softly, the car brakes very soft (brakes) then it suddenly brakes harder (transmission) then brakes softly again (brakes) then harder again (transmission).
this isn’t something that I’ve experienced in any other car.
the closest other car that does that is my 2018 G80 3.8L but it’s much smoother.
recently I’m experiencing jerky downshifts more often (the downshifts are harder and with a slight noise, sometimes louder) .. I’m not having fun with the car anymore
car modifications: Ark GT-F springs, spacers, wider tyres front and rear (20mm) on stock sport rims (245/40/19 front .. 275/35/19 rear)
the shift points are a little bit different (says other G70 and stinger owners who test drove my car) but this could be due to the fact that I’m running fatter tyres >> bit taller side wall
But this one doesn’t really bother me and it’s still very smooth
could someone suggest a fix for these hard downshifts?
the dealer claims he checked it and it’s normal and he also claims he did a software upgrade to the transmission control module .. but that obviously didn’t help
I know if I keep going to the dealer about it he would blame it on the Tyre size
I had this problem even with stock tyres (tyres changed at 40000 km) .. did try to run the stock tyre size now and that didn’t help also >> so maybe the tyres aren’t the problem here (only transmission effect tyre diameter have is on the final drive ratio)
I’m still hopeful this could be solved through software.. any help or advice?
thank you
thank you
