The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Go to the myhyundai website and download the updater tool take the sd card out of the car and put in the card reader on your pc. Launch the updater tool and it will download the necessary files to it. When you insert it back into your car it will automatically start the updateHi,
I cant update my Gen 3.8 Ultimate '15.. The button is grayed out. Someone have the files to first updated from USB??
Its a multifunction button. One tap turns audio(radio) off another tap turns entire system off.anyone with the 15 touch notice that it takes 2 or 3 taps to turn on the radio with the knob?
So did a complete re-install WITH USB stick (there was no mention of its use in the install guide or any grayed out buttons) but seems to have fixed a lot of problems I was having - see attached for latest update version info...So I am having a nightmare with the latest Mapnsoft update. First the fonts didn't match and the system would not "read" text messages. I just got the latest update 1411UP2 for my 2015 Ultimate. Now: I can not even access Bluetooth options to try and re sync phones, the jog is sometimes non responsive as is the touch screen and I have some new icon (red circle filled with white a horizontal traffic light and a black video camera profile see attached file). 15 some odd emails to Mapnsoft have gone almost nowhere and now feel the system is compromised. Their last suggestion get a new AVN shipped to dealer. The system worked fine before the last two map updates...Agggggh. Obviously others are having trouble too...anyone get a good update/install? What's the trick?
I have this problem too....but at least I know what it is now.Can anyone explain what the camera/traffic light icon on the dash does and how it works? It was added to my 2015 with the latest map update. It is there sometimes and gone at others.
Got the answer re red circle/traffic light/camera - Thanks Old Fart!So did a complete re-install WITH USB stick (there was no mention of its use in the install guide or any grayed out buttons) but seems to have fixed a lot of problems I was having - see attached for latest update version info...
Still no phone batt charge status
No WiFi options
Can not re-order presets
I have this problem too....still
weird now that i've tried it some more it always turns on after the 3rd tap so not sure if its a physical issue. also after "waking" it up, it then works fine thereafter but comes back after car is restarted.Its a multifunction button. One tap turns audio(radio) off another tap turns entire system off.
Yeah, i use the same file from SD card and put it on USB stick and it work. I can put the button with updateI think that you need the stick if the H/U has never been updated before... They would probably send you one, I'd imagine.
Wait. You put the map sid card data on the USB drive and got the Red Light Camer icon in the H/U?Yeah, i use the same file from SD card and put it on USB stick and it work. I can put the button with updateThx
I have the same model and everything as you and having the same issue. Was you able to get it installed??I do it twice and still the button is greyed out. I have the New map but without upgrade media.
Yes, i installed itI have the same model and everything as you and having the same issue. Was you able to get it installed??
Thank you. Do i put the SD card that i took out back in after install?Yes, i installed itU must use the Usb sticker 32gb
Use USB only to install update. After that use SD card to have mapsThank you. Do i put the SD card that i took out back in after install?
Thank you. I did that, but when I go to "Settings>Display" map color isn't showing where you can change to Cafe Latte, Mocha etc..or Route Guide Line & Vehicle Symbol...Use USB only to install update. After that use SD card to have maps![]()
I reinstalled with both media in at the same time (USB and SD)Thank you. I did that, but when I go to "Settings>Display" map color isn't showing where you can change to Cafe Latte, Mocha etc..or Route Guide Line & Vehicle Symbol...
Im good now thank you!I reinstalled with both media in at the same time (USB and SD)
