UAD,
Try again. Yesterday I received a message that had just the letter J.
I can understand why the dealer has a difficult time "replicating" the sound. I've been attempting to document when the sound is the loudest. I, too, get the fluttering sound between 28 and 32 mph. However, the flutter seems to be affected and made less loud or eliminated altogether by certain factors.well mine goes away for the most part after about 5 minutes of driving...guess when its warm it wants to stop making noises lol. also mines really annoying because it happens no matter what im doing at that speed...coasting, accelerating, braking, foot off the gas and brakes to slow down...so no matter what at those speeds it makes that fluttering sound.
just really weird that it happens just at those speeds...although i feel like the car does shake ever so slightly at higher speeds where my water bottle is shaking in the cupholder.
I had the same problem and it was driving me crazy. Turns out it was a from a backing plate behind the driver side front brake rotor. It had bent and was rubbing the rotor. Flutter sound was super annoying and occurred between 27 and 31 mph on accel, decel, and while coasting. They adjusted the plate and the sound seems to have gone away!!!There is a fluttering sound that I hear between 25-30mph and I cannot determine where it is coming from. It doesn't seem to be in the cabin. From my limited 'testing', it only happens when decelerating gradually (either coasting or braking lightly). Once I push the gas pedal, the sound goes away even at the same speed. Step off the gas, the sound comes back.
I believe I have seen other threads where this is mentioned. Has anyone else noticed this? Is there a remedy? It's driving me (and consequently my wife) crazy.
Has the attached TSB been performed?My car is not a flutter, its a shake and it does it regardless of temp or warm up but is less noticeable and subtle after warm up, its still there though.
I took it to the dealer yesterday and the cost given $1763. I will request the old part and speak to the tech there to determine what the actual problem maybe. There’s only one set of u joints and I am wondering if that’s the issue? I am ordering the part myself which will save me $300 more. Just hoping with COVID-19 will receive the part in the time frame given. If all goes as planned who to have the car back end of next week.Sorry, I don't know the cost. I bought the car new and the extended warranty. I did ask the service manager if the parts were redesigned to resolve the root cause of the issue that I experienced. He said no that they are the same as OEM.
My response was well then I expect the same issue again and will bring the car back expecting the dealership to make the repairs, at no cost.
Noise versus speed. I understand what others have commented and the only theory that I can propose is that the components are heating up and expanding and as a result the tolerance that was creating audible noise is diminished and becomes no longer audible. My car exhibited no discernible driving issue when it had the noise. It may have if nothing was done to correct the issue. Also, remember that noise is caused vibrations and when my car exhibited the problem the pitch of the flutter noise went from a higher to lower as the car slowed (35 to 25 mph) which may point to speed/rotation. I would put the car in neutral and rev the engine with no change (the noise was still exhibited from 35 to 25 mph). I would put it into different gears and the problem still exhibited itself but would diminish faster due to engine breaking with lower gears. When I reached 35 mph and let off the gas the issue could be heard, then I would lightly touch the gas (not accelerating) and the noise seemed to almost go away. I could repeat this until the car (drive shaft and components) heated up.
Also, I do remember reading a previous post that some repairs do not replace all driveshaft components. For my car, I was told that all components were replaced.
I hope this helps and I know it is frustrating.
Couldn’t see picture.I hope it all works out for you.
See attached image of undercarriage.
I do not know if this picture is totally accurate, but I think it is a good representation and helps give a visual.
