Kraig Wilkinson
- Aug 25, 2019
- Location
- New Jersey now live in South Dakota
Quick update on my situation: I received my map update on Friday (my software was so old, they sent me both an SD card and a USB drive as has been mentioned by other 2015 owners in the forum) and applied the update. It took exactly the 35 minutes that was estimated and afterward I have had zero issues with the system. Bluelink still works correctly with no intervention required by me and I haven't experienced any lockups whatsoever. Fingers crossed this did the trick and was mighty cheap considering the alternative.
A few other things I've noticed with the update (good and bad, personal preference):
I'm sure there are more but I thought those were notable for someone who went from the original software to the latest. If day off you're more than 2 years outdated, this is a must buy!
- System boot time is longer
- Climate screen removed all info except set temp when in Auto (I'm sure 99% of owners didn't care, but I liked having insight into exactly what the system was doing at all times, fan speed, airflow direction, A/C status) I miss it.
- BT AUDIO IS REMEMBERED UPON RESTART! I would have paid $35 just for this feature. No longer do you have to change your audio input back to BT audio each time you start the car. (Related, you can select which audio sources are cycled by the steering wheel mode button, so if you only ever use FM, BT and USB, you can uncheck everything else and then the button will only cycle those three inputs!)
- Routing is suddenly much smarter (maybe learns from the routes you take...?)
- Auto zoom is nice and map rendering in more clear
- Bluelink Drive info screen was removed (nobody probably when knew it was there, but I liked being able to see how much time I don't idling on a trip)
- You can set a delay to automatically return to map when navigating (e.g. wanted to see the artist for the song that's playing, so hit media button. After the set time (20 seconds for me) map returns without my intervention)
- Two pop up notifications: next navigation prompt when on another screen AND song update info. Love both of these!
- When reaching destination, guidance automatically stops (I think this is different from before)
- Text message integration (it's ok. I wish I could view the message in D while stopped at a light and I wish I could send dictated responses (my 15 Grand Cherokee did this with an active Uconnect subscription) ratger than just the 4 pre-generated options.)
I agree with EdP. For the price it is well worth it.I still can't decide if to stay with 12.5 on our 2015 ultimate or go to 14. Sounds like a toss up so far.
