Mark_888
- Jan 9, 2009
The article makes the point that GDI has pluses and minuses, and one of the minus is extra carbon buildup. It is commonly stated in many other sources that GDI puts extra demands on oil due to increased fuel dilution (more fuel getting into the oil) compared to fuel injection. Personally, I would only use a full synthetic with a GDI engine if I had one (I don't).Mark, the source you quoted makes the point that EGR is the source of some buildup. As a mechanical engineer I would debate the "soot" point though. The reason for GDI is that a higher compression ratio can be used and the charge can even be burned when leaner than normal, so if particles are being made, and I don't doubt you there it is more likely to be caused by EGR or crankcase venting. Some of our smog controls aren't totally logical. The original ppm requirements were set up so the biggest engines could pass smog. We are now requiring extreme measures to get minimal improvement. Again if your Genesis of any engine is turning the oil BLACK get your smog controls checked.
Bill
Many on this forum have noted that Genesis GDI tail pipes seem to vent more soot than non-GDI engines, and requires a bit more frequent cleaning in the rear bumper area.
