2015 3.8L Hyundai Genesis sedan trunk liner removal to access factory Lexicon amplifier
Hugheytx
Hello. I have a 2015 3.8L Hyundai Genesis sedan and I need help to properly remove the driver's side trunk liner covering the factory Lexicon amplifier. I have removed the obvious pop rivets and screws but I am still having trouble. The material is very stiff and tucked in and and I am afraid I may damage if I bend or pull too hard . Does anyone have instructions on how to do this to access the factory amplifier? I have the 14 speaker Lexicon speaker system if that matters.
Did you pull the weather stripping off
Wow, no I did not. I was not aware this was required. How do I remove it without damaging it? What is involved to carefully remove
and put it back?
and put it back?
its easy. it has a little lip that slides into a slit that's cut into the stripping if i remember correctly.
scroll down to the 7th or 8th post it shows the steps to remove the trunk liner might as well get rid of tht bracket while you are in there to prevent the wires from snapping.
There is no 7th or 8th post. Do you know where I can find these steps for liner removal? I want to check out the amp.
