Shifting Issue with G80 (2-3rd gear only)
gengenis
Genesis G80
Curious if anyone has seen this issue with a 2017 G80 jerk/rough shifting when going into 3rd gear only? All other gears are smooth. I have been experiencing this issue lately with my G80 and you can feel it when it shift from 2-3rd gear. Initially it happened when I am turning and I take my foot of the gas to slow down then step on the accelerator, then you feel the jerk. Now it happens in all driving conditions.
I think it happens to me while in sport mode.
Haven't noticed in normal mode though.
I have noticed a slight jerk in my 2018 G8 3.8 RWD, not sure but i think its around 3rd gear also, most noticeable when accelerating smoothly or gradually, feel like the car changes gears but if you pull your foot off the accelerator it tricks the automatic transmission or something however the ride is smooth in general. Did you fin any diagnoses or fix for your problem? Will update if i find anything out, i have started my own thread for this here..
Genesis issued a TSB for that. You need to replace a solenoid called 35RC solenoid in the valve body. It's an easy fix.
Thank you! Where can I buy this solenoid or does it have to be installed by Genesis.
Still there. I flashed my trans fluid and it improved but it's still noticeable.
You'll need the exact part number that matches your car's make, model and engine and transmission type.
If you could pass by the dealer, they will tell you the part number. Then you can either buy it through the dealer or from Transmission Valve Body - 2017 Hyundai Genesis G80
The part that you'll need is a solenoid that is responsible for the shift from 2nd to 3rd and 4th to 5th gear. It's one solenoid that is responsible for these two shifts.
Follow this link for more info on the issue. You may also consult and confirm the case with the dealer based on this TSB.
Here is the TSB for 2017 model.
So I showed this problem of a very slight jerk while changing gears on my 2018 g80 to the dealership and they thought it could be the spark plugs at first but later diagnosed that it was caused by 6TH GEAR CLUTCH DAMPNER, and it called for replacing the whole transmission by the dealership, although I am sure you can fix the problem without having to replace the whole thing, the dealership just decides this route because it saves time and head ache. Hope this helps. I attached a pic of my actual invoice.
Can't see the invoice!
Man you're awesome. Thank you. I will just go ahead and replace it. At this point it will not hurt anything. I already took it to a transmission shop and they said it's all good with the transmission. So I will go with your recommendations.
Exactly! That's how I normally re-produce it but sometimes just driving with my foot on the pedal and it does it.
I hope I do not have to go that route, only have 66k miles on it
Upon reading the TSB I rather have the dealer change it lol, too much work 😂
Any news?
I have the same problem
Hello Husam am having like a rough gear change when under low rpm 2nd and 3rd gear, i feel like a tough push.. i have genesis g80 2017 3.8 what is the reason and what part do i have to change in the transmission? Thank you
You'll need the same part numbers as mentioned in the TSB that I attached above. But first try to change the transmission fluid if it helps.
Im having an issue very similar to this on my 2018 g80 sport, does this apply to 2018's as well?
I'd start with ATF fluid change first. If it does not help, then you may try replacing the solenoids
