B'zintheBurgh
- May 31, 2020
- Genesis G70
update...mine finally got fixed by the dealer. no issues since. not sure what they did, didn't need to replace the whole sunroof.
How long has it been since the fix?update...mine finally got fixed by the dealer. no issues since. not sure what they did, didn't need to replace the whole sunroof.
probably 6 months ago now. no issues since. Took two attempts. the first time the dealer denied hearing anything. the second time, they said they had their "sunroof" guy fix it. He did fine, apart from leaving some pieces loose in the floorboard that i had to have subsequently reinstalled... of course.. but got it sorted the next time in went in for service.How long has it been since the fix?
I just picked up my car on Friday and it has 150 mi. Depending on the temperature I do hear a rattling or clicking sound which appears to be coming from the rear seat light switch cluster on the headliner.I got my car about 2 months ago and it's really annoying (something is wrong with the clip i think). I went to the service centre and because I'm the first one, they don't know what to do.
t's an issue in korea and the people who were in charge of sunroof/headliner would come and fix it for them but I don't know what they will do in here.
I doubt they will do that, and according to people who had this problem it would make the noise again and again (unless they change the whole headliner).
I'm just scared because the mechanic said he had never done this type of fixing ( i hope it doesnt get worse).
anyways I'll see how it goes and tell you guys the results!
I had a lot of success doing these:I just picked up my car on Friday and it has 150 mi. Depending on the temperature I do hear a rattling or clicking sound which appears to be coming from the rear seat light switch cluster on the headliner.
I also do have some sunroof noise. I'm not sure what to do about that.
damn... i don't mind a complete replacement. my noise is coming specifically from the headliner near the front windshield, not near the sunroof. maybe if they replace the headliner the problem will be goneThe only permanent solution is complete replacement. Been there, done that, and it sucked, but it fixed the issue for real. There is a part of the sunroof metal frame folding mechanism that breaks, and then rattles, and it cannot be replaced or repaired, the entire sunroof has to be replaced. IME.
Good luck, maybe it's not my old issue. There is a headliner noise thread where they found tabs of velcro underneath that help attach the headliner to the roof where the adhesive had failed, or something like that, and they had a fix. I think one guy shoved a towel up in there in frustration and it worked also. I forget the specifics.damn... i don't mind a complete replacement. my noise is coming specifically from the headliner near the front windshield, not near the sunroof. maybe if they replace the headliner the problem will be gone
I have a similar rattle. Putting light pressure on the plastic trim of the overhead console stops it. I wasn’t very scientific about where I put pressure, and this doesn’t necessarily mean it’s coming from the trim piece. Good luck!damn... i don't mind a complete replacement. my noise is coming specifically from the headliner near the front windshield, not near the sunroof. maybe if they replace the headliner the problem will be gone
I did something very similar to test the noise. When i put pressure on the very front part of the headliner (the suede part before the sunglass holder) the noise also goes awayI have a similar rattle. Putting light pressure on the plastic trim of the overhead console stops it. I wasn’t very scientific about where I put pressure, and this doesn’t necessarily mean it’s coming from the trim piece. Good luck!
Same for me.I did something very similar to test the noise. When i put pressure on the very front part of the headliner (the suede part before the sunglass holder) the noise also goes away
