Bicster
- Jan 8, 2022
- Genesis GV70
ours was the same situation, when asked, they said the new diffs come with fluid. I knew this wasnt true, our second one burned up in 5 miles and I am positive it was dry inside. I kept mentioning to be sure to check the fluid on our 3rd one, and the service guy said stuff like "Ill triple check this one" which leads me to believe they knew the second one burned up because they never checked or added the fluid. I had no way of proving this but enough was said that is what I believe happened.
This show bad practices/procedures from the dealership. A basic checklist would have would help prevent the second diff without fluid.
Did the dealership tell you they are just replacing the diff or did they tell you they know the cause of the problem is this is a "fix" and not a "replacement"?
