My 2009 3.8L has 140K miles on it. I've never had a major repair The only engine issue has been a engine throttle sensor covered by warranty at 25K miles. I changed the sparks plugs at 100K, change the full-synthetic oil every 5K, tires typically at 38K, I elected to change front and rear struts AND inner & outer tie bars at 100K. Flushed both Trans fluid and replaced Differential fluid at 80K.
Drove her 650 miles last weekend and averaged 28.0mpg. I do most of the preventive maintenance myself. Due for a transmission fluid & filter change but unfortunately Hyundai doesn't source the o-ring required for the new filter so I might have to pass on the filter change and do a drain & fill (4 times or so). I'd really like to drop the pan and clean the magnets etc. but don't want to reuse the old gasket!
This car drives unbelievably well and I plan to keep it until it no longer does. I believe that time in well down the road!
