GreyGV60
- Jul 22, 2022
- Genesis Model Year
- 2023
If it works like AA only a small number of apps can be projected.I just connected the new wireless car play. Question: Howcome only select icon/apps show up on the car screen and not all of the icon/apps that are on my iphone? Is there a way to add them so that they do show up?
Well, even on your iPhone only certain apps work with Car Play. But every app that works on your phone with Car Play will now work on your GV60 with Car Play. Just click on the menu button on the bottom left of the Car Play screen on your GV60 and then you can scroll through them all.If it works like AA only a small number of apps can be projected.
It may be helpful to search in the G80 forums for your specific update info. I see a few threads regarding this here.I am new to genesis. Within the last month I purchased 2024 G80 Prestige Sport.
I did get the September OTA update. I have searched and found conflicting information.
My question is does the OTA have a system and a map update.?
Where do I find a place to see what is the latest map update?
Below is the information on what I have now, and I am not sure if that is the latest map update.
I connected my OBD reader and tested things out in Auto 3. The range of deceleration is certainly much tighter than with lower Auto levels, but does still vary. It seemed to me that the deceleration rate was speed-dependent - lower amounts of regen at low speeds. I could not notice much difference based on following distance or posted speed limit (as is obvious in Auto 0) - likely because the base rate of deceleration was so high, that there wasn't much higher to go.
Still a couple questions come to mind, as it seems to me that there are much easier ways to get what it seems you want:
- If you're wanting constant high rates of regen, why note use "Level 3"?
- At such high rates of regen, how much are you using the brake pedal? I didn't touch it on my drive, except for scrubbing the last ~10km/h off when I wanted the vehicle at a complete stop for an intersection.
- Why are you applying the brake so much during long road trips so as to get your foot tired? When driving on the highway, why not just set the adaptive cruise to maintain speed and following distance? You'd almost never need to touch the brake in that case.
- If you don't want to use the brake pedal at all, why not put it in i-Pedal?
What is shown there is the latest version for download for all vehicles. The latest version for the GV60 in USA and Canada is still not available for download. It’s only available OTA.This is where my confusion comes from.
The Website says the following vehicles to download an update .
My vehicle is listed with the map version that is shown on the list.
Why does it list my vehicle to download a new version if I already have the latest version?
Where can I find what is the latest version?
Doesn’t Auto level 3 limit the vehicle to selecting full or no regeneration? Selecting say Auto 1 allows it to scale between Auto 1 and 3 as necessary based on road gradient, vehicle distance, and vehicle speed.Auto level 3 is great. I don't need to use the brake pedal for most situations. If I need more braking, I pull the left paddle for max regen.
i-Pedal is not as efficient as level 3 because it is full time AWD.
I think I exaggerated. I leave it on auto level 3 99.9% of the time.
I remember now why I use auto level 3 vs. level 3. Auto level 3 uses GPS and the regen is more predictable and stronger than auto level 1 and 2. Is there any difference between Level 3 and Auto 3 regen?
Sure thing.Do you mind listing your favorite CarPlay apps? I love suggestions!
Did you find the wireless carplay version to download? I downloaded what the NavUpdateInstaller said was the latest version, but my car said it was the same as what is already installed.Thanks, I figured out my issue. I was downloading on a computer that has blocked data transfer to USB via security policy, so I was transferring the downloaded directories to my NAS then copying down to another machine that I could copy to USB. That does not work...it seems the Updater software puts some additional files on the USB drive to make it recognizable as an update. I downloaded on a machine where I could put it directly on the drive and it was recognized in the car as an update.
OTA only right now.Did you find the wireless carplay version to download? I downloaded what the NavUpdateInstaller said was the latest version, but my car said it was the same as what is already installed.
