Rearview Camera Issue – 2015 Genesis 3.8 Premium (DIS-JOG model)
Timothee
Hey everyone,
I’ve had my Genesis since ~60k miles (currently at 95k), and since owning it, the rearview camera has never worked. Unlike some people who report a black or blue screen, mine does nothing at all when shifting into reverse. Parking assist beeps and recognizes distance fine.
Here’s what I’ve tried so far:
• Verified all the settings per the Hyundai TSB – everything is correct.
• Checked trunk wiring harness – wires are intact, no visible damage.
• Fuse is fine.
• Bought a replacement camera off eBay (not a PGS camera, just a regular model) for testing – still no luck.
• Original PGS camera also doesn’t work.
• If I play with the settings and uncheck “Parking Option 1” to make it a rearview camera only variant, I do get a black screen with grid lines, but no signal (same result with both cameras).
So at this point:
• The system recognizes something is connected (since the gridlines show when toggled), but no actual video feed comes through.
• I don’t think it’s wiring or fuse related, since the system reacts.
• I’ve basically tried every DIY step I could find, with no resolution.
Has anyone run into this specific version of the issue (no activation at all)? Could it be:
• A head unit / software issue?
• Wrong type of replacement camera (PGS-specific needed)? *for all I know the camera I bought off of Ebay could also be faulty*
• A signal wiring issue deeper in the harness?
Any suggestions or guidance would be much appreciated.
Thanks in advance!
Hey everyone,
• Fuse is fine.
So at this point:
Thanks in advance!
Had the same situation in my 2015. It was under warranty and the dealer replaced the head unit.
Have you physically checked the continuity for all the camera wires from camera to head unit? I have a similar problem.
When it gets cooler around here I’m going to get an alldata subscription and verify pin to pin. I’ll post here with wire colors and what I did.
I also have a bad blend door actuator and a broken wire to my trunk release, so I’ll be in the guts of the dash anyway. As you know, the shitty wiring routing is the subject of a tsb. My bet is on broken wires.
I surely hope so... I don't mind getting in the wiring if that's what it is. Let me know what you did so I can go in and attempt the work.
So I did get the alldata subscription but it was unnecessary. Half the wires were broken and I simply resoldered all of them back together.
They were broken on the arm connecting the trunk to the body.
All fixed now!
