Hyundai Genesis 4.6 wheel caps
exodus195
There was a thread on here, but I can't seem to find it. I bought the winged cap assembly wheel hubs just to save money because I saw a thread mentioning all you had to do was take out the original ones and heat them in an oven for the flying H to pop out.
Can't find that thread anymore.
Help!
Help!
You can use a heat gun or hair dryer to seperate the OEM caps and the sticky tape should still be good. Also use the dryer or heat gun to seperate the new winged emblems.
Try this link
http://www.genesisowners.com/hyunda...hread.php?t=5082&highlight=accessories&page=2
Also want to replace the oem center H logos with winged emblems purchased on ebay. Can't figure out how to remove the center wheel caps so I can "pop them in the oven".
Tried with a screwdriver inserted into the slot, but it wouldn't give. Was afraifd I would bend the cap if I applied to much pressure, Funny, can't find anything in the owner's manual. After all, to remove the tires, you have to first remove the wheel caps. Appreciaste some advice.
Look on the wheel closely and you'll notice a little knotched out spot next to the cover where you can stick a flat head screwdrive etc.
