WardsAuto - Genesis V-6 Smooth and Powerful, But Late
YEH
NYC/MD
Along the way, the Lambda 3.8L remains amazingly composed with minimal vibration transmitted to the steering wheel.
Any clatter underhood is well-isolated from the cabin, which is no small accomplishment for Hyundai considering the NVH shortcomings associated with its direct-injection 2.4L 4-cyl. in the relatively new Sonata.
It helps that power is conveyed smoothly and efficiently to the wheels via the auto maker’s first internally developed 8-speed automatic transmission from South Korea, aided by an enhanced torque converter with lock-up capability.
Whether toggling through gears manually (using Shiftronic) or in automatic mode, the steps are precise and clean. No paddle shifters are available with the V-6.
When it’s time to pass, open the throttle wide while cruising along in seventh or eighth gear and the transmission kicks down a full four gears. The engine howls in approval as the Genesis bolts forward.
An aluminum carrier and plastic oil plan underneath make the new transmission lighter.
The 3.8L’s torque peak of 291 lb.-ft. arrives on the high side – at 5,100 rpm, while the previous peak of 264 lb.-ft. came in earlier, at 4,500 rpm.
In between the R-Spec and the 3.8L in the sedan will be a smaller 385-hp 4.6L Tau V-8. The mix is expected to remain 65% V-6 and 35% V-8.
Whether the 4.6L V-8 stays in the portfolio much longer remains in doubt. Hyundai already announced it will drop the 4.6L in the Equus flagship sedan, leaving the 5.0L Tau as its sole engine.
Don’t be surprised if the 4.6L disappears from the Genesis range, as well, within the next few years. In that application, the 5.0L Tau could be offered both in high-output and detuned versions, Hyundai insiders say.
Through June, Genesis sales totaled 15,454, up 19.9% from like-2010, which places it eighth in a field of 25 vehicles in Ward’s Lower Luxury car segment.
John Krafcik, president and CEO of Hyundai Motor America, says he expects Genesis sales this year to surpass the 30,000-unit threshold easily.
http://wardsauto.com/testdrive/genesis_powerful_smooth_110718/
Don't know why Wards injected the whole pointless diatribe about a more powerful V6 engine being "too late."
It's not like V6s and V8s (or even V12s in the super-luxury segment) are going away anytime soon in the luxury segment - which is growing.
The real interesting tidbit here is that the engine mix is expected to remain 65% V-6/35% V-8, which goes against the prior report which gave a much lower V8 take %.
Who knows - I've never had an issue with my V6. 300 hp with the gearing is plenty in this type of car imo. I did a jack rabbit start just last weekend to get over three lanes of traffic, and the tires spun LOL.
if someone wants the V8 they are going to buy a V8. if hyundai doesn't offer one then you may lose the sale. given that ratio provided and the number of sales they state, you're looking at approximately 5,000 Genesis V8 customers a year that may go elsewhere for the V8....
There is no mention of dropping the V8. Just dropping the 4.6 V8 and replacing it with the 5.0 V8.
Canada is getting V8 as in R-spec only.
Not sure they may change into making detuned V8 down the road but for now (and possibly in US next year also) R-spec may be only V8 option for Genesis.
If people can't handle the suspension or things added onto R-spec, they may have to leave for another V8 car.
