Vibration in steering wheel while turning at low speeds
train21reb
2011 V8 Genesis sedan. I've had it about 4 weeks and just noticed a small vibration in the steering wheel when I'm backing out of a parking spot or turning out of my driveway.
Any ideas? Will definitely take it to the dealer tomorrow morning.
From what you have stated I would say you have a tire problem. check the wear on your tires. Look closely for dips, cupping or wear on one side of tires. What I think you are feeling is uneven grip at slow speeds. Also, do you still have the OE Dumbflops on your car? If so then for sure its the tires.
The tires? Really? The car is only 1 month old...has about 2000 miles on it.
There was no vibration this morning so it may be gone. But if it repeats, then I'll definitely head to the dealer.
Why wait? For peace of mind take it to the dealer now. They can at least rule out certain things even if they can't replicate the problem.
Topic MOVED. This is not a technical service bulletin!
I did notice the 4 weeks but thought you may have bought it used. With only 2000 miles tire wear would not be the issue but a bad belt in a tire could cause the same problem and more so if the weather was cold and the tire had set overnight.
