Thanks for the links, I'll check it out Tim!
I called the detailer today, they said I shouldn't have washed the car so soon and to let the wax dry. Does this sound like a cover up? The car soap I used doesn't strip wax. I live in Florida so I think it would be dried after like 2-3 days with the heat. They are willing to let me bring the car in so they can look at it and apply another coat of wax. Do you think this will fix the issue and hopefully it wouldn't be temporary.
If it is the Clearcoat you are seeing the swirls, another coat of wax is just a Band-Aid.
Actually, they would use a paint sealer/finishing glaze, not a wax, to fill in the swirls and hide them.
Problem is, as soon as you wash it, the sealer is going to thin out and the swirls will re-appear.
The good news is it's highly unlikely that they damaged the paint beyond repair of any decent swirl remover, such as
Wolfgang Total Swirl Remover 3.0 + Wolfgang Finishing Glaze 3.0 (known as the Wolfgang Twins) or
Meguiar's Ultra-Cut Compound M105 + Meguiar's Ultra Finishing Polish M205.
Either one (or many others) would easily repair the issue, once you learn how to use them.
There are less expensive tools you can use than the Flex, such as a Porter Cable 7424XP, that will give you the same results.
It just takes a bit more elbow grease to get the results you want, along with a bit more technique.
The Flex XC 3401 VRG is by far the easiest to learn and has the bonus of being very safe for rookies.
You would have to try (very hard) to burn the paint with one of these units.
Here's a link to a less expensive, but still very good "Do-It-Yourself" kit.
http://www.autogeek.net/wolfgang-porter-cable-swirl-remover.html
P.S.,
Does your car look like this?
http://www.autogeekonline.net/forum/auto-detailing-101/47904-new-car-swirls.html#post644700
