fazerG8R
- Feb 26, 2012
I'm aware of the stagger and a lot of people stagger their after market wheels. I'm no mechanic but I don't understand why stagger would affect the traction control?
Different diameter tires and wheels front to rear, (staggered) rotate at different RPM's. If the traction control system is set up to recognize this, no problem. This is what the coupe's TC does. When the same size wheels and tires were fitted to a Coupe, the traction control thinks there is a problem, that is one set (front or rear) is slipping and cuts engine power to compensate. (This seems to be reported when they fit a set winter tires of same size). The sedan uses the same size tires as stock, so I assumed staggered tires would cause a problem with the TC.
